2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Can I replace the screen?
So I'm looking to replace the screen of my macbook, and all of the screen replacements are very expensive. I found one on ebay that is relatively cheap, but the only problem with the screen is that the inverter on it has been cut. If I purchase the screen and a replacement for the inverter, should I be able to replace the screen? The reviews on the product say you cannot use the screen since the inverter is cut but I feel like you should be able to replace it. Thank you!!
Add a comment
1 Answer
Chosen Solution
Can you point to what you call the inverter looking at this teardown of the display: MacBook Pro Retina Display Teardown. Keep in mind taking the display apart is not easy! As you can see even the skilled IFIXIT team damaged the LCD panel. While this might be a cheaper part if it’s damaged you’ll likely can’t salvage it.
While it’s more expensive I only install full assemblies! MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly
Sorry no real cheaper solution other than finding a parts system which has a good screen.
Replace a display compatible with the model A1398 Late 2013 to Mid 2014 MacBook Pro 15" Retina laptop. Includes the 2880 x 1800 pixel 15.4" Retina LCD screen, display cover, bezel, FaceTime HD camera, clutch hinges, Wi-Fi antenna, camera, and display data cables. Image
Product
$314.99
Score 2
Add a comment
Add your answer
chriswdzik will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 101
