MacBook Pro models with a 15" display
8251 Questions View all
Replacement LCD not working, rainbow colored vertical lines
My original LCD cracked so I ordered a new LCD for model A1286. Having replaced the LCD I now only get a white background with rainbow colored vertical lines covering most of the center of the display.
Concerned that this was an issue with my disassembly I reconnected the old (cracked) lcd and it is still working perfectly (apart from the crack). Therefore I don't consider this to be an issue with the connections.
Connecting to an external monitor still works. I also tried resetting the PRAM and PMU but makes no difference.
Any advice for next steps would be greatly appreciated.
Score 1
Add a comment
1 Answer
Chosen Solution
Since your old LCD works and the new one fails, I have to think the LVDS cable is OK. Check to see if the new LCD is the same brand and part number as the old one. If they are identical, I would say the new one is defective. Check the reputation of your supplier, was the part new or used?
Score 2
Add a comment
Add your answer
Paul Solomon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,626
