Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
screen blank after replacement
Hi really hoping someone here can help!
I have replaced the screen on my iPhone 7 last night and at first it wasn't working but after a reboot it was fine.
However I realised I had done the home button wrong and it wasn't sitting flush, this was annoying me so I opened it up this morning to change this.
Turned it off first and didn't touch the screen connections.
When it was done I tried to turn the phone on but am now getting no display.
Please help me fix this its driving me crazy!
Score 1
2 Comments
- Did you disconnect the battery before re-working on your screen?
- Now, if you connect your iPhone to your computer, is the iPhone detected by iTunes?
- If you connect the old screen back, do you get something on the display or also black? (Provided the old screen was still showing an image before).
CAREFUL: disconnect the battery first before replacing the screen.
by
I didn't no, I didn't re work on the screen though I only re did the home button...
I haven't tried yet as I'm at work and don't have a cable but the home button feels as though the phone is on....
Old screen was very badly damaged and came apart when removing so I don't have it anymore
I have definitely learnt a lesson regarding disconnecting the battery here!
by
Add a comment
1 Answer
Chosen Solution
Based on your feedback, you either damaged the screen or the image/backlight circuit on the board.
Screen could have been damaged mostly if the cables got damaged when re-opening the iPhone.
Or at board level you may have damaged the image circuit or the backlight circuit (most likely).
Connect to a computer and see if the iPhone is identified in iTunes to confirm that it is turning on. Pay special attention if iTunes says the iPhone needs restoring; in which case it may be in DFU mode (which shows no display) and need updating or restoring first.
Trying a new screen on (or the old one had it been still available) will confirm or rule out a bad screen.
If all above fails, you’ll need to troubleshoot backlight and display circuits on the board. Micro-soldering tools and skill will be needed for that.
Score 2
Add a comment
Add your answer
Katie Garner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 1,514
