Does this laptop need a battery to work?
When I plug in my adapter I get an orange light for about 2 seconds and the fan goes on and then off then It turns white, but once I remove the battery then and plug in the adapter by itself the fan turns on and some of the keys turn white and you can hear the hard drive but the screen will not display anything. Is this because of the battery? Does the battery power the motherboard or will the power adapter do it just fine?
Update (07/18/2018)
I got the enternal monitor to work, but I can't get the new monitor to come on. Do I need to do a driver update in order to get the new monitor to work?
Tj Daddy it should come on with the power adapter unless your battery shortens things out. Remove the battery and connect an external monitor, then connect the power adapter and let us know what happens when you try.
by oldturkey03
I hooked it up to an external monitor and nothing is happening . I hooked my phone up to a usb and it was charging it. I just hooke up the external monitor and still nothing. Note the F5 light is on the power light is on and the wifi light is orange also the cap light goes on and off when I push it. I must tell you I took it apart to add a new touchscreen monitor. Is it possible I did not put it back together right? Also I notice that the fan will come on for a few seconds and then It will go off again and then back on.
by Toni
Replacing the display is probably why it doesn't turn on. Disconnect the display video cable and try to start the computer without the display, if it works then the problem could be a video cable or the display. If it still does not work then the problem would be the motherboard.
by DrGlowire
