Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Questions View all
Need to replace HDD
Hey Dan,
Is the Aura SSD a blade SSD?
My issue is I NEED to replace my HDD because I can't back it up due to an update, rendering my iMac useless (literally)!
So I would prefer to just get a regular SSD with an adapter rather than going the trouble of replacing the blade SSD. This way I can plug in my old HDD after and transfer data.
Does this make sense?
2 Comments:
What is your exact model? Look it up here using your systems Serial Number EveryMac - Lookup as you had piggy-backed onto someones else's question I want to make sure I aim you correctly.
by
Why do you need to replace the HDD?
What do you mean you can't back it up because of an update?
by
Add a comment
Here are the following upgrade options for your Mac: https://eshop.macsales.com/upgrades/imac...?
It would be easier to replace the 3.5" inch HDD with a 2.5" SSD. Taking apart the iMac is a hassle already. You shouldn't take it apart if you aren't a professional.
Add a comment
Of course it makes sense, the blade SSD is expensive and slower than a standard m.2. Adapter does work, i got on in my retina MBP
Update (24.07.2018)
iMac Intel 27" EMC 2546 Blade SSD Replacement
Thats how it is done.
If you changed a Iphone Display htan u can do this aswell.
I changed my Blade SSD with a M.2 SSD:
https://www.amazon.de/Green-Interne-Fest...
The M.2 SSD is around 30 percent faster!
The stock does 420 MB/s and the M.2 with adapter does about 550 MB/s
Score -2
Add a comment
Add your answer
Kenzie Yango will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 5
All Time: 77
