Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
Getting hot during boot
Hi I have a 6s plus getting hot during boot right at cpu and pmic I was wondering if a screen could do this if I boot without screen it's normal temp with screen it will burn your finger as soon as boots it cools but I'm unsure if it's a short on pp gpu line the reading is 0.006 on that line qwick battery drain as well as wrecking battery's within a month of replacing
Add a comment
1 Answer
Most Helpful Answer
This might be a dumb question but have you tried the screen with the front camera and/or home button unplugged?
Either of those being faulty (causing short circuit) will cause the phone to heat up at the screen connector and CPU area.
I had a client come today that had a friend recently replaced their iPhone 6s plus screen. Phone was heating up a lot due to a short circuit and not turning on.
Turns out it was the front camera cable being partially ripped and plugged in causing a short.
Score 2
3 Comments:
Yes I have I think it might be a short in the lcd cable but it's getting hot right over cpu not the cables very confused and I don't have another screen to test it
by
Il test soon if it's cpu or pmic getting hot
by
In my opinion it doesn't make much sense to get concerned about cpu or pmic if the short shows up only when the screen is connected. Unless I misunderstood your description first thing to do would be to try out a replacement screen after checking carefully that lcd and logic board connectors are in perfect conditions.
by
Add a comment
Add your answer
dylanrichter44 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 152
