Washer doesn't drain after first cycle, it fills again
Kenmore 110 washer.
Have just replaced the water pressure control switch but that didn't fix issue.
Water fills to level and begins agitation. Washer DOES NOT DRAIN before rinse cycle, instead just fills a second time and causes the washer to overflow.
If i manually set it to spin, it does spin and drain, so I know that works... just can't figure out why it doesn't do it on its own.
2 Comments
Hi @kg531 ,
What is the full model number of the washing machine?
Does the timer switch move through the cycle to the rinse position?
by jayeff
Hi @jayeff The model # is 11 20712 991
I've tried swapping out the pressure level switch and I also replaced the lid switch but it still rushes through agitation and fills again without draining.
I now have a replacement timer on order- It does cycle through the stages but the timing is off. Was hoping it wasnt this because its the most expensive part to replace, but also hoping it IS this, because if not, I'll be out of ideas.
by KGusername
