Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
Constant data recovery failed loop after replacing screen.
I just re-replaced the screen, changed the digitizer, and now the phone boots. Only problem left is the phone keeps trying to do data recovery and failing. I've tried flashing iOS 11.4 via 3uTools but it keeps giving a "recovery failed" or "do not disconnect device" error despite the cable being in pristine condition. I also have to manually put the phone into recovery mode because 3uTools fails to do so (something to be cautious about). I have also tried to update via iTunes which "worked" but the phone is still in a data recovery loop. What's worst is that every flash or data recovery attempt makes the phone automatically disable itself without asking for the passcode for 1 minute or 5 minutes when finished. Please help me. This phone is eating at me.
My old post where the question was solved and answered gives some history on the phone. It now boots and is constantly attempting data recovery. You can find the post here: iPhone 6s Plus dropped, cracked screen, now it won't boot or vibrate..
Add a comment
Chosen Solution
Turns out the client gave the wrong passcode. Put the phone out of recovery mode via 3uTools and then used the new passcode they gave me. Phone restored itself and everything is fine. Had to fix vibration motor by taking it out, checking if spins, cleaning it, and putting it back in. Phone now works with no problems. Thanks.
Add a comment
Most Helpful Answer
Did you try restoring the phone if you do not need the data on it? It sounds like you did update only, it sounds like corrupt iOS firmware.
Score 3
3 Comments:
I do need the data on it but I also tried restore which didn't work. Now the phone can't boot out of recovery mode.
by
Sounds like the NAND flash memory chip which stores the firmware and data has gone bad.
Is the iPhone housing bent somewhere at the middle or have dents at the back?
by
No there are no dents or noticeable damage on the outside of the phone. It used to say "press home to upgrade" but after trying restore it only shows recovery mode/connect to itunes.
by
Add a comment
When you do an update in 3u Tools using retain data, this is the problem you face a lot. You will not have this problem with itunes. I have seen this a lot of times.
Score 1
Add a comment
Add your answer
Trick-or-Santa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 33
All Time: 1,208
