Front panel replacement,iPhone 6s Plus
Not sure what driver is required for all screws I have got #000,#00,#0 and #1 Phillips driver however not all fit.
You will need a Pentalope screw driver it's like a torque driver just a bit different you will get one in the kit if you buy the kit with the tools. There are only 2 Pentalope screws they hold the front screen to the housing. You will need a suction cup and a hair dryer or an adjustable heat gun or s small sock with rice in it. The glue on the front housing will loosen easier when it is heated but don't heat it too much you can mess some things up by over heating your screen.
It’s not for opening the phone it’s for the screws in the bracket there is three different sizes of screws 3x1.2mm , 1.6mm and 3mm screw I think?
I pretty much use a 1.5 X 25mm driver for all the screws inside of any iPhone except for the 7 and above you will need a different driver. Look at the head of the screw make sure it is a "+" and not a "y". If it is a "y" you will need a y0.6 driver for that screw
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 46
