Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Screen Replaced, tried the phone works, and then dead
Hi everyone, i was replacing the screen on an iPhone 6, i replaced the screen, and then i tried the screen with the iPhone open, everything was working except the home button and when i click it the iPhone just died and it wont turn on Again.
When i try to solve the problem i noticed the cable of the home button wasnt correctly in place.
During the procedure i didnt disconnected the battery cable.
Now the phone wont turn on and neither is recognised by the PC when i try to connect it.
1 Comment:
When i put in charge the phone it gets hot
by
Add a comment
Try disconnecting the battery and plug it back in again and see if you can power on.
Otherwise if that does not work try unplugging the home button extension cable near the screen connectors and try turning on without that.
2 Comments:
Nothing, i've tried to disconnect the battery, and it doesnt work, and i've also try to unplug the cable but nothing.
by
P.S. When i put in charge the phone it gets hot
by
Add a comment
It sounds like the backlight is dead. Do you see anything on the screen if you try point a flashlight towards it?
2 Comments:
Nope, i see nothing.
by
by
Add a comment
Add your answer
Giorgio Bevilacqua will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 38
