battery does not charge
when turned on get message that battery is low. Battery indicator indicates charge is low. Have tried to charge via 2 different usb port connectors and 2 wall adapters but do not get the battery icon to show it is charging and after trying both methods to charge stll does not show it has charged.
Score -1
Add a comment
1 Answer
Chosen Solution
Have you tried charging it overnight? Sometimes batteries are severely depleted. But if the battery still gets no power to it, my recommendation is to replace it.
1 Comment:
also clean your dock connector and make sure that you have a good USB cable. Check the dock connector for debris corrosion and bent pins.
by
Add a comment
Add your answer
manuelo249 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 899
