I can get audio and everything but just have a black screen
What is is wrong with my tv? I have a Samsung LCD flat screen tv . I can get audio and everything but just have a black screen
'''++laurasmall62++''' this could be a backlight issue as well as a power board or T-con board issue. We need to know the exact model and what you have tried. First, with the TV on a station that you have sound, darken the room. then shine a flashlight at an angle against the screen. See if you can make out any silhouettes etc. That way you know that the backlight is the issue. you will eventually have to remove the back from your TV and take a look at the boards and the wiring. Check for obvious damage like burned, leaking or domed capacitors etc. Check the wires to see if they are all properly connected. Post some images of all of your boards with your question so that we can see what you see. Use this guide Adding images to an existing question for that.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 27
1 Comment
laurasmall62 what is the exact model of your TV and what have you tried?
by oldturkey03
