The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Questions View all
Is my battery to blame, or a hardware malfunction?
Hey there. So I have an issue with Keeping the phone on. I guess I should break it down into charging vs pure Battery as I can sometimes do a poor job of explaining things properly. Note: the screen glue is worn off so I can easily remove the screen with my fingers (if I wanted to), and most of the time w/case on one of the bottom corners will be sticking up.
Turning on when charging: Turns on like normal, but 8/10x phone will instantly turn off as soon as it reaches the lock screen. But since it's plugged in, instantly shows battery life screen w/no indication (supposedly) of battery charge loss.
After unplugging when turned on: Will shut off w/o warning at various battery levels. Started off only below 20%, now could have as high as 85% when it shuts off. When you plug it in to charge it shows no signs of a low battery
Turning on when using Pure Battery: Only gets to Galaxy logo then turns off.
Add a comment
1 Answer
i would say you have a high likelyhood of these symptoms being caused by the battery. it is also possible your battery is bloating, which would push the screen off of the device while in a case.
if you could upload a picture of your battery to your post, i could verify the later for you.
However, there ARE possibilities of other failures, but their likelyhood is minimal.
Add a comment
Add your answer
nick k will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 31
