Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
Caps missing on a logic board, compared to board layout?
Hi all
just repairing a water damaged iphone 6s, or better checking for corrosion.
So far so good.
During removal of the shield covering the RF chips i slightly moved one and needed to fix that. the rf chip moved a small cap which i repositioned. was checking board layout and schematics to see what it actually is. During that i noticed that quite a lot of small caps aren't really on the board, compared to the layout.
Is this often the case on iphone logic boards ?
Cheers
Add a comment
1 Answer
Chosen Solution
There are a lot of empty pads in the RF area of the iPhone. The way to know if something should be there or not is the presence of a small dome of solder on the pads. When there is a dome of solder, then no component was ever there. If you see a shiny, flat pad, then there was probably a component there before being dislodged.
When your unsure, then consult the schematic for the proper component and see if it says NO STUFF. That indicates that the component should not be present on the logic board, even if it is in the schematic. Those NO STUFF parts are usually there during the development of the board for diagnostic purposes but not necessary for the final version.
Score 1
1 Comment:
Ah thanks a lot ! Funny thing is the cap i had to reposition C4410_RF has NOSTUFF in the schematics.
by
Add a comment
Add your answer
Oliver Berger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 119
