Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1698 Questions View all
Why is my fridge not cooling after a breaker trip?
My power breaker in the kitchen tripped... not due to the fridge but due to something else I plugged into the circuit. Around five hours after resetting the breaker I went to get some ice-cream and discovered my fridge apparently didn't actually kick back in. I unplugged it and then plugged it back in and it came back on, however, it is not getting as cold as it previously did!
Some stuff in the freezer is still frozen solid, however, other things have thawed... all the stuff is still quite cold, just not freezing. The refrigerator compartment is cold... but not as cold as it should be either.
I have checked a number of things, including cleaning the coils under the fridge, ensuring the fan is running, checked for ice build up... still not getting as cold as it was just before the breaker tripped. Cold air is coming out of the vents at the back of the freezer when the fridge is on... though I don't know if it is as cold as it previously was.
This fridge has had no problems at all up until this time so I am really confused how a breaker tripping broke my fridge! This is an twenty year-old fridge, however, I can find no actual model or make information anywhere... the fridge itself is also in great condition and has been working perfectly until now!
Any other suggestions for what I can check before having to call an expensive repairperson I can't really afford?
Add a comment
It's had five hours to warm up it will probably take five hours to cool it back down again. If the fans and compressor are still running after six hours you will need to find out why before you loose your food. As to why it did not turn back on after the breaker trip I have no idea, but it would be best to have your fridge put on a breaker of its own so this doesn't happen again.
1 Comment:
Putting the fridge on it's own breaker may be problematic... this place does not seem to have been wired the best. I did take apart the freezer compartment and found a sheet of ice under the bottom panel. The coils in the back were not frozen, however. Once I put the compartment back together the freezer does seem to be colder, however, in 24 hours it still didn't freeze a piece of meat back solid... though it is about halfway frozen going by feel. The fridge part is still nice and cold though. I need to get a temperature gauge I guess to see the exact temps in both areas of the fridge. Thanks for your suggestions, they are appreciated!
by
Add a comment
I just had this happen to me. We had a broken thermostat so it wasnt telling the fridge that it is the wrong temp.
Add a comment
Add your answer
Paige DePol will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 43
All Time: 5,708
