Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1200 Questions View all
No wifi, Bluetooth, or gps after back glass replacement
My iPhone X had a cracked back glass so my buddy offered to fix it for me. I let him and it all looked good at first, but now I have low WiFi signal everywhere I go, no Bluetooth, and my gps is not working.
Any idea on what could’ve happened?
Could it be the new glass blocking the signal?
Score 1
Add a comment
1 Answer
Chosen Solution
It's probably more related to damage to the mid-frame as removing the back glass requires a lot of hard physical prying. The antenna's are embedded in the the mid-frame and they may have been damaged during the glass removal.
Score 2
4 Comments:
So if this is the case, what would need to be replaced in order to get everything to work again? Is there a way to replace the mid-frame and would that fix it?
by
You'd have to find a source for a replacement mid-frame. Before doing that, you should also check to see if all the antennas are connected correctly and not damaged.
by
Okay I will do that. Thanks for your help and I’ll post the results
by
@refectio coulx you please tell me shere can i find all antenna connectors?
by
Add a comment
Add your answer
urr.nesto.00 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 3,401
