The BLU Life XL can be identified by its model number: L050U. This smartphone was released January 2016, has a octa/quad core processor, Wi-Fi capability and a 13 mega-pixel rear facing camera.
Charging Light on when not charging, phone unresponsive
My BLU phone hasn’t been responsive all day, was working fine last night, put it to charge before I went to bed, woke up this morning, when I unplugged it, the blue charging light was still on, and the screen was dim. Can not reset it, phone is unresponsive.
Add a comment
In my experience when I met similar problem in samsung device I changed the lcd and worked fine. When I me this issue in Motorola device it was motherboard issue. Good luck with this device
Add a comment
I had this same problem with my BLU Studio XL 2 phone. I solved it by removing my battery, waiting 10-30 seconds, and then putting it back and turning my phone on.
First, remove the back panel/ cover of the phone.
Since my phone had a built in battery, I needed a 000 Philips screwdriver, which I found at Radioshack as part of a kit. The same kit I used can be found on Amazon:
https://www.amazon.com/iFixit-IF145-348-...
After removing the screws, I used one of the little blue plastic triangles to remove the mid-frame of my phone.
I removed the battery, waited about 30 seconds, then put it back in my phone, along with the midframe, the screws, and back panel.
I pressed the power button, and my phone turned on!!
It worked normally.
'''My suggestion to prevent this happening in the future is to not shut down the phone while charging.
Add a comment
Add your answer
Nick Gazerro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 515
