Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Questions View all
Swapped logic boards to fix backlight problem, both boards bad now
I just swapped logic boards with a cracked screen MBP and my MBP that had no backlight, I thought the problem was the backlight fuse, but now both boards have no backlight when connected to either of their screens. Does anyone know what could be causing this?
Add a comment
1 Answer
Chosen Solution
A faulty lcd screen and/or lvds cable can short the backlight circuit all the way back to the backlight fuse, sometimes killing a few components along the way. Proper troubleshooting would require a known good screen and known good lcd cable and at least a multimeter and a very thin soldering iron to replace the fuses in case they have blown. What might have happened here is that you have two faulty screens that kill components on the logic board. You might be in luck since it can happen a faulty screen kills the backlight fuse only, leaving untouched other components.
Score 2
Add a comment
Add your answer
Pk11 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 48
