High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Questions View all
Ipad restarts after changing screen and ic
I had my ipad pro 12.9" dropped and the screen was broken ... First i changed the screen but i realized that the left part of the screen has a particular part not responding to touch. ... They told me i have to change ic tag ... After changing it i found the ipad is restarting on its own every short time .... And just after restarting the battery shows 1% charge percentage although it may be fully charged ! ... After seconds it returns to the real percentage ..... And then after short time it restarts again .... And so on !!
How can i overcome this ?!
Is that the screen problem ?? Or the ic ???
Thanx in advance
Score 1
Add a comment
1 Answer
Chosen Solution
Did you change the screen and IC yourself or was this done in a shop? If it was done in a shop, then you should go back and show them the problem and ask them to take a look at it. It should be covered under their warranty.
If you did this repair yourself, then take a close look at the work you did. When replacing IC's, sometimes adjacent parts can get partially or fully dislodged or bridged. Also, sometimes the IC will not seat properly and the soldered connections will be incomplete.
Score 3
1 Comment:
Thanx for reply
All these done works are made by a workshop ... And i have already contacted with them and they told me they will come and recall it again ..... I'm only afraid that the problem has no solution or the ipad can't act like before .... knowing that they don't use the original parts ... But a very high copy
by
Add a comment
Add your answer
Shady will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 365
