Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
After changing iPhone 3GS battery, the iPhone kept rebooting
After I installed the new OEM battery, my iphone started just fine. But after few minutes, it rebooted itself. Then it kept doing this again and again... Do you think I messed sth up when I replaced the battery??
Please help.
Score -1
2 Comments
3GS are very finicky regarding batteries. You may need to try a new battery. But first try a Hard Reset, see if that works. If not try restoring firmware with iTunes, see if that works. If not you may need to try another new battery.
Brad
by
i'd agree with brad... send it back or put your old battery back in . If the problem goes away with the old battery then you need to order from a different lot.
by
Add a comment
Chosen Solution
I would say that the battery you have does not have a compatible APN with the phone you have. Is your 3gs relatively new (purchased within last 1.5 years)?
If so then you should get a battery with a current APN number. At unitediphonerepair.com they have the details on all the APN numbers and sell batteries that are compatible with the new model 3GS.
Add a comment
Same problem happened with me. I did what the fellows said and worked. I installed my old battery (2009 Iphone 3GS) and its working as before (not good, but at least it's not rebooting everytime).
Add a comment
Add your answer
iphoneUser will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 3,429
