Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
Post-battery/screen-replacement issues, intermittent black display
Hi there,
So, I had a horribly cracked screen and very poor battery life and I decided to replace both of those parts. It went well and worked excellent for some weeks, but now I find that I'm having an issue when the power button/home button is pushed, the screen may just show a back-lit black display. After a few pushes, it does display the lock screen but otherwise, sometimes I'll receive calls/texts and be unable to read/answer them. I've since reopened the phone to re-seat connections and double-check that nothing was loose. That seemed to alleviate the problem for a day or two but the problem re-emerged. I've been reading and I fear that I may have placed screws in the wrong locations and caused "long screw damage". Are these issues symptomatic of LSD?
Add a comment
1 Answer
Chosen Solution
I think your symptoms are more related to a defective or low quality replacement screen. If you still have the original, cracked screen, you could try to re-install it just to see if the symptoms go away. In that case, contact your supplier/vendor and get a replacement screen or refund.
As for the LSD...yes it's possible. When you remove the screen , take a close look inside the screw standoffs. They should be black other than some blue thread locker and sometimes some metal shavings.
Score 2
Add a comment
Add your answer
Fidel Chavez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 32
