Released in March 2017, the G6 is LG's flagship phone running Android 7.0. This device is available across all major wireless carriers. Physical repair of this device may eliminate water resistance and cause the device to be vulnerable to water damage.
How to tell if motherboard has been damaged from a fall?
Dropped it from about 3 ft onto cement, glass is cracked and screen will only display one single vertical line from top to bottom. My question is there a way to tell if just the LCD and digitizer needs to be replaced or is something on the motherboard messed up too? I think I'm handy enough to attempt a screen repair but don't want to burn 100$ on a futile repair. Vibrator motor seems to respond to power button inputs and it does make a sound when power button is held like to power on or off. Thanks for your input.
Add a comment
1 Answer
Chosen Solution
Hi @dddy ,
The only way to initially tell if there may be a problem is to open the phone and to closely inspect it (use a magnifying glass if necessary) for any obvious physical or possible electrical damage that could have been caused by the fall, e.g. cracked pcb, loose components or cable connections, or “distressed” (burnt looking) components caused by non catered for circuit paths created by the fall.
If everything appears to be OK then a screen replacement (even temporary) is the only way to find out what is really happening with the phone.
Here’s a link to the ifixit LG G6 guide, which may be of some help.
Score 3
1 Comment:
Thank you, very helpful information
by
Add a comment
Add your answer
Tom Pengelley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 227
