Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
140 Questions View all
Liquid damaged, dog wee, device no longer powers on.
This happened to a friend. When I arrived to try and help, the device was plugged into the wall, in an attempt to charge it :/
Is data recovery at all possible, as it's NAND flash, or is that probably screwed? I imagine if it is, it's very expensive. I realise there's nothing that the average consumer can do as the drive can't be removed.
Add a comment
1 Answer
Chosen Solution
Animal urin is the worst kind to deal with. The machines will always smell and get condemned for the rest of their life by the manufacturer and any good tech. On top of that, the manufacturer WILL void the warranty. Apple already considers secondhand smoke systems a biohazard so I presume any type of urin counts as well. If I get to take it and it's worth stripping I'll wear gloves and take what I can out but I do not keep much; I will even throw out the chassis. I do not repair them for anyone, including family.
Your friend should just go for data and replace the machine; it's probably not going to last very long knowing it was used as the dog's bathroom. Get it repaired so it's stable enough to move the data to an external drive of some sort and erase the SSD once everything they need is off. This will certainly involve board level repair, so find a schematic for the board to use as a reference. Once you do that the board needs to be cleaned with a ultrasonic cleaner to make sure all of the urin is cleaned off.
Score 2
3 Comments:
Hi, thanks for that answer, it's helpful.
"Get it repaired so it's stable enough to move the data to an external drive of some sort and erase the SSD once everything they need is off. This will certainly involve board level repair, so find a schematic for the board to use as a reference. "
So does that mean the only way to get the data off is to get someone brave/willing enough, to get it up and running first, then get the data off. The data can't be removed without it at least powering on?
by
Yes. You either need to do the repair yourself OR pay a shop who does board level repair to bring it back to life to get the data off.
Expect to pay a biohazard fee if they are willing to deal with it.
by
Ok. Thanks again.
by
Add a comment
Add your answer
losimagic will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 87
