Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Disabled 21+ million minutes?
My iPod Touch is disabled for 21 million minutes after not using it for a few days. I tried restoring in DFU mode, but the file always errors when it is downloading through iTunes. I tried downloading the latest firmware manually, and during the restore it gets Error Code 18. I have the latest iTunes. Nothing works. Please help :(
Score 21
3 Comments
How in the world do i repair this
by
I have the same problem on my IPod 5.
by
Add a comment
Chosen Solution
John Pinheiro, here is my answer from a similar question: How to I fix my disabled iPod Touch? Apple says, "If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons." Now there is a way to erase the password, but I am not sure if this would work when you are already disabled. I guess you can always try and hope you have a Windows computer :-) Anyhow, you plug in your iPod. Open My Computer (or Computer for Vista). Click on Folder options and enable to view hidden files. Next, go to iPod_control and click on the folder named Device. If your iPod is locked, there will be a file _locked. Rename the file to _unlocked. Remove your iPod and it will be cleared. Again, not sure if it works for a disabled one. Just thought of something else. Make sure you have your library backed up.
Also, check what Apple has to say about that on here: http://support.apple.com/kb/HT1808
You can also try to use recboot available here which possibly gets your device into recovery mode.
How to restore iPod touch? another answer similar to yours. Let us know what works and how it is going.
Good Luck
Score 17
7 Comments:
+ It can be done on Mac too. ;o)
by
+ Very informative answer, covering the bases.
by
i think could be the most technologically impaired person i know. cause i can't find half the stuff so it wont unlock :/
by
kazzandra,here is a way to fix it but YOU WILL ERASE ALL YOUR DATA. Hope you got it backed up. Go into DFU Mode and restore.
DFU Mode
Connect your iPod to your computer
Turn your iPod Off
Press and hold the power button for 3 Seconds
While continuing to hold the Power button, press the home button as well for 10 seconds
Keep holding down the home button, release the power button for another 10 seconds
iTunes should now detect the iPod in recovery mode, press OK, and restore your iPod. Now you can release the buttons. If you have not reached this point, then you have not entered DFU Mode. Here is a youtube video and here another one Might help you.
by
bookmarked this one. Thanks oldTurkey03!
by
Show 2 more comments
Add a comment
If you guys want a good and works really well answer, here it goes.
Step 1: Take the Apple USB device and plug it in your iPod but not in the computer.
Step 2: Turn the iPod off.
Step 3: (difficult ;) hehe) Hold down the home button and don't let go! Plug in the USB device into the computer. Don't release the home button until you see iTunes pop up or an Apple on your screen.
Step 4: It will turn to DFU mode. It will tell you to restore.
Hope this works for you!!!
;) Good Luck.
Bizz-out!!!
Score 17
10 Comments:
But my home button is not working :(
by
This helped a lot thanks steven now my ipod is working
by
My friend and i were sitting here, and we've tried so many things that had to do with resetting it... and when we got to this one, we were both like "there's no way that's going to work. it's too simple."
and then it totally worked.
mind blown.
good job, high five.
by
thank you it worked
by
Easy Peasey!
by
Show 5 more comments
Add a comment
the same thing happened to me alls i did was plug in my ipod after restarting my computer and it went to the slide unlock screen:) GOOD LUCK:)
Score 2
Add a comment
I had a similar problem with my phone about 6 mths ago. i didnt want to have to restore factory settings because it was before the icloud and i wasnt sure how long it had been since i had backed it up.
i searched and found a program called recboot it is great (esp with windows) to easily put it back in recovery mode without requiring any altering.
my daughters ipod has just done this 22mill minutes thing as it has been off for a few weeks. i started searching again, everyone was saying the same as before.i did try plugging it in to itunes, but it kept sating it couldnt recognise it as it was locked, but there was no opportunity to put the password in, then i remembered i had this software on my laptop. I plugged it in and within seconds, it was back to just asking for the password, en voila... back to normal.
its so worth having on the computer. RecBoot, look it up. Its gold!
Score 1
1 Comment:
tried most of the options that were mentioned and none worked!! then i saw this one...RecBoot is gold! Thanks Lilli! my daughter is a happy gurl now!..
by
Add a comment
Ok, we had the same problem. Basically, what we did was plug the device in and let it charge for about 10 minutes. Then we unplugged the device after we read the post that told us what to do by going through "my computer". But by doing that, we realized that the computer was not recognizing the device. So we unplugged it from the computer, at the USB port, and then plugged it back in. ( We were hoping that this would make the computer recognize the device). As soon as we plugged it back in, the 22 million second message went away and we were able to enter the password and use the device. I think the problem was really just a low battery charge.
Add a comment
Same thing happened to my sons, what worked for me was plugging the iPod into the computer, opening up itunes and doing a diagnostics test. It fixed the problem!
1 Comment:
this was the best fix, thank you.
by
Add a comment
I have had this happen to my ipod just today! i went on here and followed the advice everyone gave, but it turns out all you have to do is plug it in to your computer for a few minutes, and if you remember your password, you can get right back on to your ipod without erasing your data!
1 Comment:
Absolutely correct ;-) if you remember your password. The issue here is that people get locked out because they do not remember their password:-)
by
Add a comment
sounds crazy but all i did was connect my ipod to my laptop and itunes said it couldnt recognise the ipod so i unconnected then conected it again and it started to sync so i slid the screen to unlock it and it did glad if i could help:)
Add a comment
i bought an ipod touch off of ebay, that was being sold for parts or repair, it said that it would not power on and and i tunes would not recognize it when connected to there pc. i had bought one that was simular before and had no problem getting it up and running. if i were you i would try a different pc with i tunes ( you might lose everything on it) but it is worth getting it back up and running. make sure your usb cord is good i have had several go bad for no reason. one of them i started off fresh and restored to factory settings like it was new and the most recent score of mine actually let me start it up and i have over 1500 songs that are mostly my kind of music that i get to keep, just have to figure out how to get itunes to let me save it and share with my other one. good luck i hope i have been some help.....:)
Add a comment
press the off button the hold off button and home button at the same time and then it should come up with connect to iTunes then you plug it in the computer and restore it that's how to get it working email me if it worked
Add a comment
Use this link to restore:
http://support.apple.com/kb/HT1212?viewl...
Add a comment
If you encrypt an iPod Touch backup on iTunes and then forget your password, you will not be able to restore from backup and your data will be unrecoverable. If you forget the password, you can continue to back up and use the device, however you will not be able to restore the encrypted backup to any device without the password. You do not need to enter the password for your backup each time you back up or sync.
Add a comment
My iPod had the 23 million thingy and my dad said it was a virus so I turned the iPod off and connected to the computer but the computer didn't say it was connected so I unconnected it and then reconnected it and the disabled sign went away and I unlocked my ipod!!
Add a comment
Add your answer
John Pinheiro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 20
All Time: 278,233
