Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
Stuck on the apple Logo
My phone will not turn on past the apple logo, and restarting does nothing but go back to the logo. It has sat on the apple logo for hours. I put it in recovery mode and it would not connect to itunes because it says the phone doesn't have a driver or no driver found and it won't install a driver. I need help on what to do, is there any way to install a driver or a different method to solve this problem? Thanks!
Score 1
1 Comment:
please help me
by
Add a comment
1 Answer
have you tried doing a factory reset threw iTunes?
4 Comments:
If iTunes doesn't recognize your iPhone, iPad, or iPod
If you connect your device to your computer with a USB cable and iTunes doesn't recognize your iPhone, iPad, or iPod, get help.
When iTunes on your computer doesn't recognize your connected device, you might see an unknown error or a "0xE" error. If you do, follow these steps and try to connect your device again after each step:
Make sure that your iOS device is unlocked and on the Home screen.
Make sure that you have the latest version of iTunes that works with your computer.
Check that you have the latest software on your Mac or Windows PC.
Make sure that your device is turned on.
If you see a Trust this Computer alert, unlock your device and tap Trust.
Unplug all USB accessories from your computer except for your device. Try each USB port to see if one works. Then try a different Apple USB cable.
Restart your computer and iPhone, iPad, or iPod.
by
I can't do most of these thing because my phone won't go to the home screen, only screens I can get it to are the apple logo screen, recovery mode, and completely dark, thanks though I'm trying the factory reset
by
Everything I try eventually ends up in the same spot; going to itunes so they can tell me I don't have a driver
by
Add a comment
Add your answer
heuer.rachel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 133
