Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
I couldn't fit the earpiece speaker bracket gasket back
I couldn't fit the earpiece speaker bracket gasket back around the metallic piece it sort of wraps around. I guess my replacement screen had some part a bit bigger than the original and the gasket runs short and I couldn't reach the screw hole. I wonder if there is some way around. I left it loose. Everything seems to work fine but guides insist on paying attention not to break that gasket so I guess it must be there for some reason.
Add a comment
1 Answer
Chosen Solution
Do you mean this thing (Step 23)?
I suspect the Apple engineers put that there to ensure some kind of proper alignment between the bracket and the cover on the screen flex. You don't need it and I have rarely been able to put it back the same way it was originally.
I wouldn't worry about it.
Score 1
Add a comment
Add your answer
Homero will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 62
