2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774 Questions View all
Help Plis FL8300, FL8302
I need these components to fix my Macbook Pro and I do not know where to find it
In a post here in the forum says that it is a Murata DLP0NSA150HL2
Where can I find this component? Is there an equivalent component?
I live in Brazil and everything here is difficult. If you can help me, I thank you.
Add a comment
1 Answer
Chosen Solution
@pcsiqueira DLP0NS is a common mode choke coil from Murata. In this case it is a DLP0NSA150HL2 Just an FYI, this is what that means:
DL = Chip Common Mode Choke Coils
P = Film Type
0N = (LxW) 0.85x0.65mm
S = Magnetically Shielded One Circuit Type
A = Category
150 = Impedance
H = Circuit
L =Feature
2 = 2 Lines
Both Digikey.com and Mouser.com carry those but only sell them in quantity of 1,000. You could always try on finding some kind of donor board and getting them of there, or try to match the choke as closely as possible with other manufacturers etc. Here are the values to look for:
Common Mode Impedance = 15ohm±5ohm
Rated Current = 100mA
Rated Voltage = 5Vdc
Insulation Resistance = 100M ohm
Withstand Voltage =12.5Vdc
DC Resistance = 0.95ohm±25%
Score 2
2 Comments:
Hello @oldturkey03 . Thank you very much for your help. You help many people with your knowledge.
I found this TDK MCZ1210DH120L2TA0G.
Common-mode Impedance [Typ.] 12Ω at 100MHz
Common-mode Impedance [Min.]
Common-mode Inductance 19nH at 1MHz (Ref.)
Rated Current 100mA
Rated Voltage 5VDC
Insulation Resistance [Min.] 10MΩ
DC Resistance 1.5Ω Max.
or DLP0NSC280HL2L
Impedance (Ohm) 28
Test Frequency (Hz) 100M
Maximum DC Current (A) 100m
Maximum DC Resistance (Ohm) 1.3 (Typ)
Minimum Insulation Resistance (Ohm) 100M
Voltage Rating5VDC
Withstand Voltage12.5VDC
MountingSurface Mount
Minimum Operating Temperature (° C) -40
Maximum Operating Temperature (° C) 85
What is your opinion? Which one of these would you use?
by
I would use TDK MCZ1210DH120L2TA0G. The original one has a Common Mode Impedance = 15ohm±5ohm which could be anywhere between 10ohm and 20ohm so that would be at least close to the TDK one.
by
Add a comment
Add your answer
PAULO SIQUEIRA will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 99
