Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Questions View all
Why my samsung Galaxy S5 LCD doesn't turn on?
I have samsung galaxy s5 and its lcd doesn't turn on by one press. it's screen is like an old tv screen that is fading because of screen lamp disorder. sometimes I press many times the right boton or the down boton to turn it on. some other times I have to take off battery and replace it again to turn it on. pls help me to solve the prob.
7 Comments
Hi,
Does it work OK when you have the charger connected and switched on?
by
Once the phone is running does it work ok and does it come out of sleep mode ok ?
by
@jayeff Thank u for ur response. sometimes it switches on when I connect the charger to show the phone is charging and also when it gets full charge some other times it doesn't switch on when I do the same.
by
@jimfixer Thank u for ur response. It doesn't go to sleep mode. it seems that something is wrong with lcd that it turns on difficult and after many tries. As I told b4 its lcd is like an old tv screen that its screen lamp is burning. how mayI send the photos or film of my tries to turn it on. Is it possible to send photo in this site?
by
Hi,
Has the phone been dropped or gotten wet at all?
Here's how to add pictures to show what is happening
Adding images to an existing question
by
Show 2 more comments
Add a comment
Most Helpful Answer
Hi,
It may be that the LCD screen backlighting is failing or perhaps the screen cable connection may be slightly loose etc.
Here's a link to the ifixit Samsung Galaxy S5 Display Assembly Replacement guide, which should be of some help in gaining access to the flex cable connection and also in replacing the LCD screen if it is deemed to be the problem.
Before dis-assembling the phone try the "dimming" test in the phone's hardware test menu to check if it shows what the problem may be.
Here's a link to the ifixit Galaxy S5 - Quick Test Menu
Samsung Galaxy S5 Display Assembly Image
Guide
Difficulty:
Moderate
30 minutes - 1 hour
Samsung Galaxy S5 Image
Guide
Difficulty:
Very easy
1 minute
Score 1
Add a comment
Whenever I deal with phones that have a LCD that does not work as intended, it is a hardware problem. This means that something inside of your phone is broken, not working as it should, or is faulty. I recommend you try replacing the screen, and if it doesn't work, return the screen, and I would check each of the ribbon cables of the screen, and of the battery to make sure there is no kinks or tears. Hope this helps!
Add a comment
Add your answer
Leila Khoshabi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 265
