Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Previously Jailbreak iPhone will no longer turn on
Previously Jailbreak iPhone no longer turns on
I believe my iPhone 6 might be bricked. No longer turns on just shows Apple logo and shuts off . force boot /respring didn’t work. Doesn’t even pop up in iTunes. Tired using ireboot same thing with iTunes. I’m here asking what do I need to replace to get it working again.
Add a comment
Most Helpful Answer
Is this happening with or without the charging cable plugged in?
How long does it stay on the apple logo and is it looping?
Sounds like software needs to be restored to be honest. I'm guessing you tried safe mode for jailbreak if I remember correctly you hold volume up while turning on.
Score 2
Add a comment
1st Q response : it happens for both. While being charged and no connected at all
2nd Q response : I would it says on for about 10 seconds then shuts off and no loop just starts up displays the apple logo then shuts off.
How do you think I fix the software if it is the problem. . Since the iPhone does not register as connected on iTunes. Should I replace the logic board or what do you think .
Thanks for replying
1 Comment:
Sounds like a battery problem.
by
Add a comment
Add your answer
Oscar salas will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 45
