Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1366 Questions View all
I can't call after the repair.
I recently fixed the power button on my iPhone because it broke. But when I called after turning on the power, it became a forced boot. While looking for a problem, a fever broke out on the main board on the FPC camera side. The phone also worked when the front camera cable was removed and powered on. After repeated this process several times, it is now impossible to boot when the front camera cable is connected. Is this a problem with the front camera flex? Is it a problem with the FPC camera?
Add a comment
1 Answer
Chosen Solution
Do you see physical damage on the front camera connector on the logic board?
If not then try getting the front camera assembly replaced because if the connection to the proximity sensor which is on the front camera is damaged it will cause the phone to reboot when a call is started.
Score 3
1 Comment:
Thank you!!!
by
Add a comment
Add your answer
james kim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 65
