Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
My iPhone 6 Plus's display is turning on by itself, and when shaking
So i've been looking for answer everywhere, but couldn't find it. Here's my problem:
When i shake my iphone, like lean it back or just tilting it, when e.g i'm taking photos, my screen turns off and on by itself, and then the slide to power off button appears.. it's not the raise to wake option, i don't have it, it's a physical problem. My question is, do you guys know what's the cause? By the way, sometimes when i hit him on the back, the problem stops, but it appears again in couple of days... Oh and also, when i touch the right part of the screen, from top to bottom, my display turns off.. lol...
I'd be very grateful if you guys helped me.. :)
(oh and sorry for my english, it's not that perfect.)
2 Comments:
Has the phone been water damaged before?
by
No.. never...
by
Add a comment
1 Answer
Hello Grabakaba,
This is very tricky issue, especially since I've only seen it happen once before, and it was because a friend of mines phone was physically bent out of proportion. Although I do not recommend it, I want to recommend taking it to Apple. I say I do not recommend it because they'll most likely just try and sell you a new phone, but for all I know, you may find someone actually useful. On the other hand, what I recommend is seeing about a screen replacement, If your phone has never been water damaged and is not bent in any way, then the screen may just have a loose ribbon cable may be causing your issue, especially considering if not properly put on, many issues can arise.
Hope this helps!
2 Comments:
Well i can’t take it to Apple because 2 reasons, my warranty has expired and there is no official Apple store from where I am, Serbia...
the thing is, 2 months ago i gave my phone away to a local service store and they fixed the problem i had, ghost touch thing, and after that, this issue started to appear.. so i guess they screwed something.. I guess i’ll just take my phone and go there, and tell them the issue
by
I don't know their warranty on repairs, but if it started after they fixed it, then it could be their fault and they would be liable to fix it. Otherwise, I wish you the best of luck on fixing it!
by
Add a comment
Add your answer
Grabakaba will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 1,079
