Repair guides for a large selection of Kodak digital and film cameras.
260 Questions View all
Camerafehler Mistake Nr E 45
2 Seconds after turning on the camera the display shows "Kamerafehler (Camera-mistake) Nr. E 45. After that no more action is possible.
What can I do?
Kodak gives no more longer service for this camera.
Thank You so much for answer!
Score -1
Add a comment
Chosen Solution
It is possibly giving you the error because the lens may be stuck in the barrel. It is possible that your battery does not have enough power for the lens function. First connect your AC adapter or USB cable. Hold the shutter button while switching on the camera. Take a look at the lens, if some of the lens rings look crocked or not lined up try to gently wiggle it while holding the lens down. You can also try to to VERY GENTLY push or pull the lens when it extends. But be very careful since this could dislodge the lens of the guides. Take a look on here
Score 3
Add a comment
6 meiner kameras von kodak-samsung und canon hatten das gleiche problem - lege die kamera fuer einige stunden in das gefrierfach - benutze gute neue oder aufgeladene batterien und probier ohne SD karte - Ich hatte 90 % erfolg - 6 of my cameras had the same problem - remove the battery and memory card - put the camera in the freezer for a few hours and try with very good or full recharged battery - I had 90 % success with this
Score 2
3 Comments:
Did you have any trouble with corrosion on the internal parts of the camera after?
by
i wouldn't put them "naked" ind the freezer - a large "ziploc" bag would be the minimum.
but since it's mostly a mechanical problem - the freezer might not really be necessary - the best and easiest way is the one oldturkey03 described
by
I lebe in neu sealand und die kameras sind vielleicht weniger temperatur schwankungen und staub ausgesetzt als in deutschland - oldturkey03 is richtig mit seinem rat aber es war sinnlos mit einigen meiner kameras mit innenoptik oder kodak twinlens- Ich benutze keine plasticbags um kondensation zu vermeiden - aber ich trockne die kameras sehr gruendlich - ich vermute die kaelte im gefrierfach zieht das material zusammen und laesst die linse frei - aber das ist nur eine vermutung - in jedem falle habe ich in den letzten 15 monaten auf diese weise 6 kameras gerettet - ich hoffe mein deutsch ist noch verstaendlich nach all den jahren in auckland
by
Add a comment
hi tuerkey - I never got any problems with condensation - just make sure the lens shows to the bottem of the freezer to avoid condensation running inside - one of my kodaks V550 saw the freezer 4 times in 5 months and is still working - I think cleanness of the lens is important - this is one reason I never use a soft camera bag which gives off lint and microscopic tread material - sometimes I start the camera and clean the lens with cotton earbuds and the same fluid i use to clean CD/s and cassette recorder heads - which part of the globe are you living ? cheers willi
Score 2
1 Comment:
Thanks for your hints, does this work on other errors or you are not sure?Auckland is beautiful, lucky you...good luck in the rugby! :-)
by
Add a comment
2 Comments:
hallo willi, ihc denke du hast recht. die materialien reagieren auf die temperatur und dementsprechend lösen sich diese "klemmer" wieder. theoretisch ginge das auch mit einem kältespräy - aber das würde leider auch feuchtigkeit mit hohem druck in das gerät pressen - aber wenn die kamera in einem beutel wäre, ginge es mit einem spray am schnellsten (ich habe kältesprays um rostige schrauben zu lösen)
dein deutsch ist noch sehr gut.
by
Bist ja noch sehr gut zu verstehen :-) Ich weiss ja auch wie du dich mit der sprache fuehlst. Geht es mir ja genauso. Ich glaube auch das die kaelte die linse schrinkt und das sie dann wieder beweglich ist. Ist ja ein guter trick solange man die kondensation kontrollieren kann. It is a good trick for as long as condensation can be controlled. Good Job willi...;-)
by
Add a comment
pollytintop - non of the cameras showed any error massage - so I'm not sure - of 7 cameras 6 were working again and stuff rugby lol - i prefer soccer and chess with the computer
1 Comment:
what??? you must be in hiding at the moment! AB's beat us on Sunday...oh the misery. Thanks for the extra info on the camera errors..I have 4 or so of c,m and z series all with lens problems(think are all zoom flex not lens stuck)...back to the drawing board.
by
Add a comment
btw - the kodak Vseries has twinlenses and can therefore not been pulled or pushed to free them - the lenses are covered by a medaldisk which swings to the side inside the camera - sometimes the disk get stuck because of a combination of worn off metal,dust or spilled fluid - I bought a V 610 last month which would open a little and then close down - after cleaning the cover in and outside the mechanism is working perfectly and I absolutely love this camera
Add a comment
stuff rugby and i don't care who beat who lol - good luck
Add a comment
Add your answer
Tom Kleinert will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 3,289
