The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Power button not not working and goes dark after unpluggin power cord
Hi,
My MacBook has a strange behavior.
I can't power it on using the power button (maybe keyboard defect) and to make it worse as soon as I disconnect the power cord it goes off but it shows that the battery is 47% charged.
The Battery is not charging and not discharging (tried several adapters) Apples built in check says "good".
I can't perform the SMC reset because of the defective power button. From the inside it looks good, no obvious water damage or corrosion. I went to Apple and they told me this was a logic board failure due to water damage.
Is there a way to fix this?
Thanks for your help!
Add a comment
1 Answer
Chosen Solution
Where are you located?
Your logic board sounds like it needs repair there are people who can repair it. They have the skills and needed equipment.
Otherwise, you'll need to replace it. Here's what is involved: MacBook Pro 13" Retina Display Early 2015 Logic Board Replacement
Score 1
2 Comments:
Are you sure that it is the logicboard? :/
Is it possible that the charging circuit is broken and the keyboard? Im living near munic
by
I'm suspecting the charging circuit and its part of the logic board.
Here's a listing of all of the repair business's listed in IFIXIT: IFIXIT listed business's The ones I know that could help you are in the UK which is likely too far for you.
by
Add a comment
Add your answer
Mc Plesch will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 44
