If the LED light goes away as soon as you plug the Xbox, it's because the power dies down. This means the DC power is insufficient. It could be due to power conversion failure or that there is a bad connection from the wall outlet to the power brick. I've had this type of failure and the starting cause was the three-prong AC cable to the power brick connection was loose..
1. pressing harder on it helped..
2. later I had to replace the cable for one with a longer connector,
3. and later the power brick failed.
So either of these reasons could apply in your case. In my case, the power brick was a cheap one and the result was understandable but an Xbox shouldn't have that issue. If you never had the issue before of it didn't give any sort of issue, try 1 and 2. But if the issue has happened before, the power brick may be due for replacement. Do the test advice here to determine if you need to replace it.
https://support.xbox.com/en-US/xbox-one/...
The Xbox. was released on November 2013 so it has been 4.5 years minus the time from release to your purchase, so depending on how frequent and instense you have used it.. that could help explain the power brick failure. (sorry for possible confusing language, I'm not a native english speaker)
But my orange light wont go away even after a reset unplugged everything and still orange light wont go to white might it be a consol problem or my charge pack
by Joshua Merchant
Mine won't go away etheir or turn on and I'm Brooke and suicidal at this point
by Andrew bunton
@ajb263 I’m sorry to hear that man. Hang in there, your life has meaning and is valuable. Love you man.
by Garrett Smith
