Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2264 Questions View all
Why the speaker and microphone are not working
Hello, this is my first question on this website, first of all I am verry glad that we "phone technicians" we can find this awesome place to change our experience and to improve it as well.
So now back with my question... I got an iPhone 7 after a screen replacement(in another shop) and I am just wondering what could be the reason for not working the microphone, ear speaker and speaker, all in the same time, the button is also off when I make a call...
I have already replaced the ear speaker but no effect, I also analyze the flex cable and looks ok.
Some hints from better technicians?
Best Regards,
Razvan
Add a comment
Chosen Solution
Do you know if the replacement screen was the only reason it went to another shop first?
The iPhone 7 series of devices suffers from issues with the Audio IC and weak traces on the pcb which crack and break. It is a similar design flaw to the iPhone 6 Plus, known as Touch Disease. On the iPhone 7 series, the weak traces are underneath the Audio IC.
The microphones and speakers are all controlled by the Audio IC at one level or another so it is possible that this could be the root cause. Do you know if this phone has been dropped or flexed a lot?
Score 2
2 Comments:
The customer said that the screen was only cracked... everything else was ok.
No idea if it was dropped or flexed...
So you suggest that Audio IC could be the reason?
If I will replace the audio IC it should be fine?
Thanks a lot.
by
I am just suggesting that this is a common failure on the iPhone 7. You need to continue to troubleshoot the device and rule out all possible "modular" issues first before going on to a micro-soldering solution.
by
Add a comment
hi
i have the same problem and if it is under warrenty apple will repair it for u or they charge £300 for replacement
or
Keep using your phone with a bluetooth to receive and make calls normal
xxx
Add a comment
Add your answer
Razvan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 8,477
