Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Bad Backlight after Repair?
I was replacing my iPad mini 1st gen digitizer and I took the LCD out to clean it. One I connected the LCD it wouldn’t turn on. So I put a flashlight on the screen and I could see the screen. The iPad it’s self works. Would it be board level repair or just a new LCD?
1 Comment
How much would it be to get the micro soldering job done?
by
Add a comment
1 Answer
Chosen Solution
You probably disconnected the LCD while the battery was still connected. That can cause the backlight filter to blow. This does require a micro-soldering repair.
It may be the LCD but the only way to know would be to probe the backlight filter to see if you have the proper voltage getting through to the LCD.
Score 3
2 Comments:
This is the most likely issue.
by
As for repair, look locally for a reputable shop that does micro-soldering repairs. There are many shops worldwide that do this so you shouldn't have any problems finding them.
If you can't find one locally, then consider mail-in repair. There are several reputable micro-solderers patrolling this forum. You can also click on my profile to learn more about my services, at the very least, it can serve as a data point.
by
Add a comment
Add your answer
Owen Baker will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 14
All Time: 386
