Washer fills and timer advances but it will not agitate, nor empty nor
I have a 70 series model 110 20852 990 kenmore washer.
Serial # CK 1120916
Type 111
The washer will fill with water but do nothing else. The timer advances and the door switch will stop the timer when opened if it is in spin cycle.
It will not agitate, nor drain, nor spin.
The problem appeared suddenly.
It seems as if the door switch works because it will stop and start the timer during parts of the cycle.
The Water level switch works as I can finely control how much water enters the tub from low water to high water. Bailing the tub out and restarting the cycle will fill with water again.
Temp select switch works as different temp selects properly pick which water line opens.
The machine just stops at fill and the timer moves along and nothing else happens.
1 Comment
Water will drain from the tub when I take the hose out of the stand pipe and put it under the level of the water in the tub.
by Chris Baugh
