Trusty old MacBook won't turn on
Old faithful 17" MacBook is not turning on / powering up whatsoever. No whirring, no chime, no lights. The battery had drained completely but is now charged. I thought maybe it just needed several hours on charge because it's not been used for several months, but it is still not powering on with a full battery (green MagSafe light).
Have already tried:
- SMC reset, with and without the charger plugged in. Power button still unresponsive.
- Unplugging the battery from the motherboard for a few minutes and plugging it back in. No difference.
- PRAM reset. No response.
It had no issues last time it was used (albeit some time ago). It's been on a shelf since then.
Has it died randomly of old age? Is it salvageable?
Add a comment
1 Answer
Most Helpful Answer
Give this a try: Disconnect the battery from the logic board, disconnect the mag-safe. Press and hold the power button for 10 seconds. Reconnect the battery and engage the mag=safe. You should get a spontaneous reboot.
Score 2
1 Comment:
Thank you, was definitely worth a shot but sadly hasn't worked this time.
by
Add a comment
Add your answer
Amy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 32
