Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Questions View all
My phone don’t turn on fully after upadate
Hi guys
So I’m recieving this real silly issue about the Samsung logo after an update.
I just keeep reviewing Samsung logo when I turn it on.
This happened directly after updating to the latest version
I have tried using Odin to repair it but every time I received failed rather than pass. I tried a few times around 5 times to receive the same answer.
I was wondering if anyone would be kind enough to help me solve the issue thanks.
Thanks in advance.
1 Comment
I’m receiving other issues with my phone now appears with this message. Any help is great.[image|1445494]
by
Add a comment
Most Helpful Answer
Are you flashing the correct model firmware and also with matching region code?
You can find your region code by force turning off the phone if it's bootlooping via volume down + power + home for about 10 seconds.
When it goes off immediately hold power + volume up + home then release power when you see the samsung logo.
Keep holding other buttons until you see the light blue recovery screen.
Then wait for a bit and the recovery menu should appear and display some text.
Look for applied multi-csc code: xxx
xxx will be your region code, follow that and you will know which region firmware to download for your phone when you download from Sammobile or Updato.
Also take note of the model number printed on the back of the phone and in ODIN download mode, either should be matching the downloaded firmware model number.
Score 2
2 Comments:
Hi thanks for the reply I’ll give it a go and try again. maybe I’m just not doing something correctly.
If I need any more help I’ll let you know thanks.
by
I forgot to tell you, if your firmware is too up to date it wont allow flashing of older firmware in some cases.
It will usually not allow you to flash the first few files called sboot due to mismatch security bit or something like that.
What does it error on by the way? Usually I can tell what is causing it.
by
Add a comment
It’s like right at the end
Add a comment
Add your answer
Rakesh will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 42
