Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
592 Questions View all
MacBook Pro 2011 doesn't turn on. Completely dead.
I was playing League of Legends in my MacBook Pro Late 2011 A1278 when it suddenly turned off. No messages, no sounds, just turned off.
When MagSafe is connected, the lateral lights that indicates battery charge turn on normally. If MagSafe is disconnected they don't work at all. If the battery is disconnected but MagSafe connected, pressing the button makes the first light blink for a few seconds; pressing it a second time makes all the lights flash for a few seconds.
I opened it, and checked all the connections. Then I:
• Removed one RAM memory and tried to turn on.
• Removed the other RAM memory (and placed the first one) and tried to turn on.
• Disconnected battery, disconnected MagSafe, connected MagSafe again and connected battery, and tried to turn on.
• Disconnected MagSafe, disconnected battery, connected MagSafe and tried to turn on.
• Danced an apache dance to the moon and tried to turn on.
I just wanna die. Thank you.
Add a comment
1 Answer
Most Helpful Answer
Sounds like your logic board is toast ;-{
follow this IFIXIT guide to pull the logic board so you can make a detailed inspection looking for any damaged components. Hopefully, it's an easy repair otherwise you may need to find someone with the needed tools and parts to fix things.
Post a picture of anything that looks questionable.
Score 1
Add a comment
Add your answer
Diana Cervera will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 82
