Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 Questions View all
How can I replace the optical drive temperature sensor (922-9214)?
I have a late 2009 21.5" iMac and the fan runs at full speed constantly.
My friend knows a lot more about iMacs than I do and so she tried some resets and has also run some tests on it. She found that the optical drive temperature sensor needs to be replaced.
I have ordered the part (922-9214) and would like a step by step guide on how to put it in the machine.
I have a cousin and a friend who have both pulled apart and put together computers before, so I am planning to ask one of them to put it in for me, but I want to give them a guide to follow.
Any help would be much appreciated. Thanks.
Add a comment
1 Answer
Most Helpful Answer
The guide you want your cousin to follow is this one: iMac Intel 21.5" EMC 2308 Optical Drive Replacement Step17 gets into the taking it off. the drive.
Frankly, You really don't need to pull the drive out only loosen it a bit to sneak the cable out as the sensor is right on top, just get to Step10 (you can even see it in the guide picture below).
I would recommend you run this great app first to be doubly sure: TG Pro It will show you the sensors and fans. If you buy the full version it can give you a diagnostic on your systems cooling.
Score 1
Add a comment
Add your answer
danish222 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 63
