Repair information for the Samsung Galaxy Tab 12.2, released in 2014. Model numbers: SM-T900, SM-T905.
My samsung galaxy wont turn on or not charge
i plug in a new charger in my samsung talbet galaxy it wont fit so i tried to showed it in then the screen went black and wont charge. I tried a soft restart but that wont work either. please if someome can help me i would appecide it. thank lyn
Add a comment
1 Answer
Most Helpful Answer
Hi @mouse77 ,
Hopefully you haven't damaged the charge port and possibly caused electrical damage to the systemboard when you "it wont fit so i tried to showed it in". ( I assume that you meant that "it didn't fit so I shoved it in")
Use a strong light and a magnifying glass to examine the USB port.
Check that all the pins are there and that they are all straight and parallel with each other.
If the pins are bent or touching or broken this may be the cause of the problem and as I said, hopefully there are not more problems.
Firstly if the port is damaged then it will have to be replaced as it cannot be repaired and then after that further testing needs to be done to find out if there are any more problems.
If the charge port is damaged, here's a link to the ifixit Samsung Galaxy Tab Pro 12.2 Battery Replacement guide. It is useful as it shows how to open the tablet, so that access to the charge port flex cable is possible.
Here is a link to a supplier of the charge port. It is shown to give an idea of the cost of the part. It is not a recommendation to use the supplier. There are others online that may suit you better.
If this all seems to daunting, contact a reputable, professional mobile phone or laptop repair service and ask for a quote to repair the tablet.
Score 1
Add a comment
Add your answer
lyn will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 21
All Time: 234
