The fourth-generation Surface Pro tablet, released October 26th, 2015.
208 Questions View all
Surface not turning on - burned diodes
Hi dear ifixit users!
I have an Problem with my Surface. It's not turning on anymore after someone changed the screen on it. I quickly dissasembled it and spotted these 3 diodes that looked burned (I circled them in for you too):
Now my questions is can anyone tell me which diodes these are? I want to try to replace these 3 to see if it works again. It's currently not even turning on even with the charger plugged in. The Charger lights up tho. Do you guys think this might be the solution that fixes it? Or might be there something that is also broken that doesnt let the surface start?
Thanks in advance
Update (04/21/2018)
(Here I will attach any extra Pictures that are asked to keep the first Post clean)
Score 4
1 Comment
I change the battery on mine (twice !!!) and it doesn’t charge the new battery.
However, the old battery is charged when plugged in.
If anyone has any info..
Thanks
by
Add a comment
Most Helpful Answer
@md20 for now I would stop trying to do anything with this board. It will be complicated to find the right parts since a schematic and/or board view would be needed for that. Those are still a bit hard to come by. Also, you must consider the reason why those components have failed. There could be further underlying issues with the board. Yes, I do agree that the failed components are a reason why you cannot get any signs of life from your Surface pro 4. Post some clear close ups of those components for us to see.
Score 1
11 Comments:
Hi I understand your point of view but since these diodes are often only a few cents worth it's worth a try. :-) I read on another iFixit user's post that someone couldn't power his SP4 up with only the battery but with only the charger and that he had to replace on of the diodes (which are according to the Internet MBR0540 40V 0.5A SOD-123 SMD Diodes) and it worked again. Since I am not sure tho if all of these are the above named diodes I do not want to risk it to totaly short it. It would be handy to know if all of these tree diodes are the above named diode.
by
@md20 I totally agree with you. That is the reason why this site even exist. We are all trying to fix device that the manufacturers do not give us enough information about. It is really not uncommon that devices fail because of components that only cost a few pennies. The issue is that we do not know what those components are. I would never suggest to ever give up. Repairs like this are just not easy and quick to figure out hence the need to take a closer look at your board.
by
@oldturkey03 Yeah indeed I agree with you on that. They all look the same but since I do not have another Board to take meassures I can not say that these are 100% the same :/ I ordered the above named Schkotty Diodes tho I mean a few bucks for 50 Diodes is not going to make me poor :D Still waiting for someone to confirm it tho that these are the same diodes so I can put them on the board and test it out
by
@md20 any chance you can zoom in onto those components? Maybe we can help you out with further identification.
by
@oldturkey03 Tomorrow I will try to make an sharper close up image but I zoomed into the previous picture on my phone which I uploaded on here already and cropped it to that part where the burned out diodes are. The picture had a better quality on my phone so a lot more details can be seen this way. I hope you can see and maybe identify them. I made an seperate comment where I attach all the other pictures that are asked to so the first post stays clean.
by
Show 6 more comments
Add a comment
You already have spear parts just look at the picture
Score 1
Add a comment
No, this is not what I meant. The copper pad under the left diode pin was damaged due to the heat of the burned diode or the desoldering. Therefore also a new diode does not fix the problem because the left side of the diode is just open, connected to nothing.
But I think I found the answer myself. The left side of the diode is connected to right side of the capacitator cluster a little to the left of the diodes, See picture.
Actually, I found this by beeping through a damaged board so I cannot finally confirm this. If anyone can confirm this would be great!
The pad below the left diode connection is very small and only connected through a via. It is NOT connected to the area directly around which only becomes obvious if you take a very close look. So make sure to ONLY connect the left pin of the diode to the capacitator, NOT the area around.
Score 1
2 Comments:
Hey mate, you got your Surface working again?
by
First, many thanks ! Had exactly the same issue, and I managed to save the very Surface pro 4 I'm using to write this comment thanks to your suggestion. I can confirm that my Surface pro 4 is now able to run on the battery only. I did put a thin isolated wire to connect both points in your image, and I used the spare diode to replace the battery diode as it was the only one that was tested failing.
by
Add a comment
Hello everyone. I have a question connected to the replacement of the diodes. Does anyone know where the left pad of the battery diode (upper one of the two) is going to? Or maybe can check it quickly? I have a mainboard here where the left pad seems to be damaged by the burned diode or the desoldering. Thx
Add a comment
Hope it is helpful for you
Add a comment
Add your answer
Musti will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 29
All Time: 5,517
