Broken Thunderbolt Connection Replacement Needed
Hi, I have a broken thunderbolt connection on the above equipment. More info can be found here
https://www.blackmagicdesign.com/api/pri...
Does anyone now where I can buy a thunderbolt port to replace the broken one with? To be clear it’s the connection in the box that’s broken, not the thunderbolt wire that connects to it.
Thanks!
Add a comment
1 Answer
Chosen Solution
Based on the link you provided, it appears the UltraStudio Mini Recorder uses a Thunderbolt 1/2 connection, which uses a MiniDisplay port connector (source: https://en.wikipedia.org/wiki/Thunderbol...)).
Here is a source: http://estore.circuitassembly.com/catego...
1 Comment:
Thanks very much!
by
Add a comment
Add your answer
Ryan DeFreitas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 295
