The Samsung Galaxy A5 (2016), an Android Smartphones released by Samsung Electronics in 2016.
58 Questions View all
Phone dropped in sea water
I have a Galaxy A5 (2016), previously I had some other phones dropped into seawater,
I just used isopropyl alcohol, but now I ran out of it, so I was wondering if i could just simply submerge it in distilled water without disassembling the whole phone as I don't have access to a heat gun.
Add a comment
Chosen Solution
Hi @loximity ,
How do you propose that the distilled water is going to displace the sea water etc.?
Some of the sea water may get "stuck" inside the phone as you are not washing it away with distilled water by just submerging it in it, simply trying to dilute it somehow. Also allowing it to dry without all the sea water having been removed still allows for corrosion to occur.
Only sure method is to open it up and dis assemble it. You can then use distilled water to flush away the sea water.
Also whilst the battery is still connected there is still the potential for electrical damage due to the salt water conducting electricity (not the distilled water - it doesn't conduct)
Score 1
Add a comment
Most Helpful Answer
See this old thread.
Can I use distilled or deionized water to clean electronics?
I do with @jayeff comment.
You should open up the phone, flush away any salt water residue with distilled water, disconnect the battery, and maybe then bathe it in distilled water until you can get some more alcohol.
Score 2
Add a comment
Add your answer
Loximity will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 14
Past 30 Days: 50
All Time: 5,956
