The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Help with MacBook Pro temperature sensors
I have a 2015 MBP 13" Retina (A1502) which has a strange kernel_task issue and shows errors in Diagnostics ------ PPN001( i don't know what this code means) , PFM006(SMC issue), PPF003(Fan issue).
I want to be able to try cleaning out the insides, especially the temp sensors. Can someone help me regarding their locations?
Add a comment
Most Helpful Answer
I don't think general cleaning will address these errors.
Diagnostics finds electrical faults not general temp issues. You likely need to take the logic board out and do a deep inspection looking for corrosion damage and/or damaged components.
Can you fill us in on what happened with your system. Did you have a spill or get it wet at some point?
Score 1
Add a comment
Check board for liquid damage may have a sensor issue. Also inspect trackpad flex and trackpad for any corrosion on the connection points.
Add a comment
Add your answer
chuck lozano will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 715
