Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Questions View all
Screen Replacement iMac 2013 Late 27"
Hi,
I need to replace my broken screen and I've found this.
https://www.ebay.com.au/itm/323159525390...
Is this model right for my iMac 2013 Late 27"?
Thanks.
1 Comment
Well, the item is no longer available on your link, (also 670 dollars is REALLY expensive).
I did find this,
https://www.ebay.com/itm/LCD-Display-New...
it's less expensive than the link you sent and it's also the right model.
by
Add a comment
1 Answer
Chosen Solution
@paddy27 always double check the label on the back of your panel. It will have the manufacturer as well as the right panel version etc. listed on that. Even within the same iMac model there may be variances on the display. Replace like for like and search by the label to ensure a proper functioning.
Score 1
Add a comment
Add your answer
Patrick Kim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 972
