4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
I have an iPhone se error 28 help fix
i have a black iphone se that had water damage and wouldnt turn on so i opened it up and let the motherboard dry out and i roughly put everything together and it was able to work again so i decided to reformat with itunes and when it installs it stops mid way with an error 28 can someone help me please
Add a comment
1 Answer
Chosen Solution
With water damage, you have to fully decontaminate the logic board before doing anything else, otherwise there will be latent issues down the road.
The water is inside the phone, on the logic board and under the shields, even under the IC's. The real problem is the mineral deposits that can cause short circuits or the corrosion that is taking place as the water evaporates. Leaving the power on the device accelerates the process. The longer you let a phone sit, the more time you are giving corrosion to damage your logic board. The saltier or harder the water is, the more damage will occur. The water needs to be displaced, not evaporated.
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
You should also replace the battery if it has swollen. Resist the temptation to pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
Score 2
3 Comments:
I have done what you said but used the rubbing alcohol that was in my house which is 70%, is that bad to use. I did not realize the number difference till after. Should I go buy 90% tomorrow. The battery is still in good condition so it shouldn't be a problem. So the issue is the board? and also thanks for the help
by
I don't think using 70% alcohol is critical, it's just better to use >90%.
by
ok sounds good should i let it it in the alcohol for a while or just rinse and dry
by
Add a comment
Add your answer
Victor will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 110
