2.3L 4cyl or 3.0L V6, 6th Generation
427 Questions View all
Horn continuously goes off. Pulled relay.
Have a 2000 accord 4 cyc. Horn continuously goes off. Pulled relay. Brought to Honda. They say they have not seen this??? They swapped the airbag with a civic and said it solved problem. Wanted $1150 for new airbag. I did not do this there. Bought an airbag off ebay (used) for $90, installed it and then the relay. all was good until I pressed the horn in car. Switch engaged and latched on... Continual horn again so pulled relay. No idea what to try next?
Score 1
Add a comment
1 Answer
Most Helpful Answer
@kevhavi I never resolved my issue with my horn, but maybe @oldturkey03 commented something that'll help you with your situation:
Am I able to replace the horn switch without replacing the airbag?
Good luck!
Score 1
Add a comment
Add your answer
kevhavi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 21
All Time: 1,129
