A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
Why is it beeeping
The beep code is 1-1-1-1-1-1 th en turns off I've tried removing all the parts and I had a cpu that was the same one I switched th e cpus and still beeps. I know it's not the ram cause I just got the ram 2 days ago. I haven't taken out the cemos yet I'll try that but if anyone knows how to fix I need the awnser.
4 Comments
@mcofficalplays what make and model is your computer? What motherboard is it? Did it have this issue before you replace the memory? Have you tried the old memory
by
@mcofficalplays
list out the make and model as mentioned from oldturkey03
check on your graphic card and power supply also.
by
My computer is the Brodcast pix slate g 1000 i tryed removing the graphics card and I got this without ram but,with the ram type
by
@mcofficalplays try opening up the casing, take pictures of inside mainboard, perhaps install a working graphic card and see if it boots up
by
Add a comment
Chosen Solution
The broadcast Pix slate G 1000 is not a typical computer. This is a highly customized machine with proprietary hardware for broadcast television video. I suggest posting on their forum for an answer.
Score 1
1 Comment:
i will post there
by
Add a comment
Most Helpful Answer
If you just Google for your brand of motherboard suffixed by "beep codes" you may well find the answer.
Score 1
1 Comment:
I can't it's a special motherboard made by the computer company that is the same one that made the computer.( The pc is a switcher)
by
Add a comment
Add your answer
McOfficialPlayYT will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 301
